My PC has unusually high temps reported by OpenHardwareMonitor.
CPU (5800X) used to idle at 75C. I reapplied my thermal compound and reinstalled the cooler and now it's at around 65C. Which is an improvement but not much I think.
I have about 5 intake and 5 exhaust fans on the case. 5 of them run at 1800RPM and 5 at 1200RPM. The CPU cooler is Cooler Master Hyper 212 with both fans installed in push pull config. Room's ambient temp is on the higher side.
Any advise on bringing down these temps?
https://linustechtips.com/topic/1342746-high-temps-diagnosing/
chances are its not reading correctly. Download hwinfo64 or Ryzen Master and confirm. These are known to work and show correctly with AMD Ryzen CPUs.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14768109
Both HwInfo and Ryzen Master seem to agree with OpenHardwareMonitor on the temps.
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14768137
You did remove the plastic from the base of the heatsink before installing it correct?
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14768149
Yes. There's no plastic on the bottom of the cooler heatsink. Just aluminum and copper. I'm twice as sure because I cleaned the old thermal compound with alcohol when reinstalling it.
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14768152
Mounting pressure problem maybe?
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14768171
3 minutes ago, Trinopoty said:
Don't know how to test that. I tightened the cooler mount screws properly. Till it stopped turning.
Go into HWinfo64 and look at your Core VIDs or VCOREs. What are they like??
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14768320
1 minute ago, Trinopoty said:
~Snipped Photo~
What Windows Power Plan are you using?? Update all your drivers and chipset drivers?? BIOS updated to the latest non-Beta BIOS?
Also, a Cooler Master Hyper 212 is gonna barely cut it for this high end of a processor at 8C/16T. Keep in mind that Zen 3 CPUs tend to run hot and idle at high voltages, creating excess heat.
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14768336
I use the "High Performance" plan. I'll check for update to my drivers and BIOS and get back.
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14768341
Do we have a CPU cooler tier list or something like that? Wondering if I should go with a 360mm AIO. Maybe a NZXT Kraken?
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14768346
Actually, yes there is (I'll probably add it in my Signature for those interested in a quick link). You could do that, as long as it performs very well. Have you looked at reviewer's videos of the cooler and see if it's worth purchasing?
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14768349
I knew of the PSU tier list only. Good to know we have a cooler tier list as well.
I need to do more research on AIOs but NZXT Kraken is the one most readily available when I searched both online and offline.
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14768720
After updating the BIOS, the Core VID is hovering around 1.0V (down from 1.4V before the update) and temps are hovering around 45C to 55C.
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14769492
That's much better than what they were before. A beefier CPU cooler is something I'd recommend. Personally, I like air coolers so the top of the line you have is a Noctua NH-D15 or a be Quiet! Dark Rock Pro 4. Just check to make sure they are compatible with your case as they are tall coolers. Likewise, check to make sure the AIOs fit.
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14769649
I have a Define 7 XL so space wouldn't be an issue. I'll upgrade the cooler as soon as stock becomes available.
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14770274
Sounds good. Keep us posted on how everything turns out!
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14770991
  • 1 month later...
I upgraded to a NZXT Kraken X73 360mm. The temps haven't improved much. Staying around 40C at idle. Then again, my ambient temp is on the higher side.
I'll try fiddling around to see if maybe there's any airflow obstruction that can be fixed.
Also installed a 3080 Ti at the same time so that could be contributing to the higher overall temps.
https://linustechtips.com/topic/1342746-high-temps-diagnosing/#findComment-14897094
