For a good PCIe 3.0 500GB drive, you're a little low. You can find them all day for $75. $60-65 puts you into compromise territory, where you're going to get drives with no DRAM (slow) or QLC (slow).
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1342273-high-speed-ssd/#findComment-14764721
I’m just trying to get a psu and ssd for under 180
https://linustechtips.com/topic/1342273-high-speed-ssd/#findComment-14764732
M.2 or Sata? Maybe check the wd sn750
SPEC LIST:
  • CPU: AMD Ryzen 9 5950X w/ NZXT Kraken Z73 360mm Liquid Cooler
  • GPU: NVIDIA RTX 3090 FE
  • RAM: Corsair Vengeance LPX 32GB (4 x 8GB) 5000MHz CL18
  • Motherboard: MSI MEG X570 Godlike
  • SSD: Samsung 980 Pro PCIe 4.0 1TB (x3)
  • PSU: Corsair AX1600i
  • Case: NZXT H710
  • Monitor: Alienware AW2521H 25inch 360Hz 1ms
https://linustechtips.com/topic/1342273-high-speed-ssd/#findComment-14764738
9 minutes ago, the gamer that is bad said:
Either as long as it is faster than my old Sata 2 ssd
What is your current SSD? Not many SSD's ran at SATA 2 speeds........ thats very, very old.
For normal consumer application, any SSD with a DDR cache (any SSD that is from a name brand and isn't super cheap) will have this, and they will all work about the same since a normal user would never feel the difference in day to day workloads.
https://linustechtips.com/topic/1342273-high-speed-ssd/#findComment-14764780
I have a old inno disk evergreen ssd and I have allot of stuff I want to move from my had to a new ssd
https://linustechtips.com/topic/1342273-high-speed-ssd/#findComment-14764796
If its if a SATA 2 SSD, does your PC have SATA 3?
But yea, basically anything would be a good option. I am a fan of the WD Blue SSD's, if not a Samsung; Samsung is basically the go to.
https://linustechtips.com/topic/1342273-high-speed-ssd/#findComment-14765131
My pc has sata 3 it is a tuf b550 board
https://linustechtips.com/topic/1342273-high-speed-ssd/#findComment-14765163
