Help with upgrading
Go to solution Solved by shouldervalley,
just get another graphics card ''upgrading'' the 8320 to i5 would be wasting money.
My 2 options are:
1: i5 4670k with either an Asus ROG mobo or Gigabyte G1 Sniper mobo.
2: Sli another GTX 780 and will need to upgrade my psu.
Any suggestions would be appreciated.
Current specs:
CPU: AMD FX-8320 3.5GHz 8-Core Processor
CPU Cooler: Zalman LQ-315 Liquid CPU Cooler
Motherboard: Asus M5A99X EVO R2.0 ATX AM3+ Motherboard
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 780 3GB Video Card
Case: Rosewill BlackHawk ATX Mid Tower Case
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified ATX Power Supply
Optical Drive: Asus DRW-24F1ST DVD/CD Writer
Operating System: Microsoft Windows 8 Professional (OEM) (64-bit)
Monitor: BenQ RL2455HM 60Hz 24.0" Monitor
Case Fan: Noctua NF-F12 PWM 55.0 CFM 120mm  Fan
Case Fan: Noctua NF-S12A FLX 120mm  Fan
Case Fan: Noctua NF-A14 FLX 68.0 CFM 140mm  Fan
Forgive me El Guapo. I know that I, Jefe, do not have your superior intellect and education...
https://linustechtips.com/topic/134212-help-with-upgrading/
PC specs.3570k, asus p8z77m pro, 8gb corsair vengence 1600MHz, XFX 550w, seagate barracuda 1TB, MSI 660ti, cooler master k350, cooler master hyper tx3 evo.
https://linustechtips.com/topic/134212-help-with-upgrading/#findComment-1785599
Question is, do you really need an upgrade?
Ryzen 9 5950x | NH-D15 | ROG STRIX X570-F | G.Skill 32GB DDR4 | MSI Ventus RTX 3080 | WD Black SN850 1TB PCIe 4 | Samsung 850 EVO + 860 EVO 1TB | Corsair 5000D Airflow
Dell S3422DWG | Dell S2721DGF | Corsair K70 RGB Keyboard | Logitech G502 Lightspeed | ATH-R70x
https://linustechtips.com/topic/134212-help-with-upgrading/#findComment-1785600
I kinda thought so.
It's more of want vs. need.
https://linustechtips.com/topic/134212-help-with-upgrading/#findComment-1785607
780 SLI if you must but i see no point in either as your monitor is only 1080p and AMD CPU will be just as good in performance vs a 4670k
i5 3570K | Gigabyte Z77-UD5H | Noctua NH-D14 | GTX 670 | 8GB DDR1600mhz G| 2x Kingston HyperX 120B SSD | WD Blue 1TB | EVGA 650w 80+ Gold | InWin GrOne | BitFenix Recon Fan Controller |
https://linustechtips.com/topic/134212-help-with-upgrading/#findComment-1786379
