500 would most likely be enough, but it really depends on which unit you have.
https://linustechtips.com/topic/1341631-how-much-power/#findComment-14759747
What cooler are you using?
I've got a 9600k and I had similar problems with my OC attempts. Tons of freezing until I upgraded the cooler to keep temps down. The best stable OC I've done so far is 4.8GHz all core, which was stable-ish with the previous cooler. I think with the new cooler I could try for higher now (max temp under load is just 77C on one core) whereas before that I was going over 100C.
https://linustechtips.com/topic/1341631-how-much-power/#findComment-14759757
6 hours ago, BlissReaction said:
Thermaltake TR2
That one is rated as B-tier on the PSU Tier List, it has solid review numbers on Amazon, and 500W should be enough headroom for overclocking considering your graphics card is a GTX 980. I don't think the power supply is the issue.
What are the temps and clocks like on your CPU when you overclock it?
(It's B-tier assuming it's the TR2 Gold, the TR2 Bronze is D-tier, but even then, I don't think this is a PSU issue)
https://linustechtips.com/topic/1341631-how-much-power/#findComment-14761972
57 minutes ago, BlissReaction said:
The gpu hits about 80°c and the cpu 66°c
That GPU temp is high, but that alone shouldn't cause freezing. Looking at old reviews, the reference GTX 980 regularly ran at 80C in demanding games like Crisis 3 at stock. That's not a good temp, but it's not unexpected for that card.
What clockspeeds are you trying to push them to? And how did you try to validate your OC?
https://linustechtips.com/topic/1341631-how-much-power/#findComment-14763503
Try setting bios to default and play some games, if no freeze, then OC is unstable.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1341631-how-much-power/#findComment-14763517
