High pressure 120 mm RGB fans for AIO
Solved by oeci,
I went forth and bought 3 120 mm Alpenföhn Wing Boost 3 ARGB High Speed to replace the radiator fans plus 3 140 mm Alpenföhn Wing Boost 3 ARGB to replace the case fans. I still need to tweak the fan curves but so far the noise is far less disturbing than before. I know that it's probably subjective perception but to me the new fans are less noisy than their predecessors. I reason for this could be the fact that they move more air and thus can be run at lower speeds to achive identical or even better cooling. After all the old case fans were 120 mm ones while the new ones are 140 mm. All in all I would say the fan swap has been a success.
