Running a fluid dynamic bearing at lower than specified spec sheets
Solved by HanZie82,
Unlikely, its just the manaufacterer covering their selves. If the fan wouldnt go as low as manufacterer spec, ppl would be able to warranty a perfectly working fan.
Soukamoshirenai ·
Posted in Troubleshooting1 -
7
SpaceOperator ·
Posted in Windows1 -
6
4
QuantumSingularity ·
Posted in Phones and Tablets1 -
21
10
Cramig88 ·
Posted in Peripherals2 -
play_circle_filled
Latest From Linus Tech Tips:
Why it Was Almost Impossible to Put a Computer in Space
play_circle_filled
Latest From ShortCircuit:
I’m kind of an iPad hater, but this is MAGICAL. - iPad Pro M4
