Hi everyone,
For my girlfriends appartment I'm trying to find the best (i.e. what fits the speakers and vinyl player) audio setup combined with a home projector.
She currently already has some stuff lying around which she wants to use. I was wondering if the following combination would be sufficient or if you suggest different options:
Speakers (Already in the appartment, but not connected to anything):
Wharfedale Diamond 220 (2 units)
Denon DP-200USB
My idea was to connect these devices to the following amplifier:
Denon PMA-30  (https://www.denon.com/nl-nl/product/amplifiers/pma-30)
With regards to the projector, I'm still looking at both long throw projectors with a ceiling mount or a short throw laser projectors, but it likely needs to be connected via BT.
Projector options thus far are:
Samsung Premiere LSP7T
Epson EH-TW7100
Epson Epiqvison LS300
But this requires some more research.
Thanks in advance!
https://linustechtips.com/topic/1340536-audio-setup-help/
16 hours ago, LBakker said:
Hi everyone,
Denon DP-200USB
Epson EH-TW7100
Thanks in advance!
Hey. The audio section of the LTT forums is already somewhat obscure, and the portion pertaining to projectors or home threatre setups even more so. I would highly advise you ask on the AVS forums, you’re much more likely to get more competent and frequent responses. Cheers!
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1340536-audio-setup-help/#findComment-14753373
