Hello everyone,
First thing, here is the problem: I get frame drops every time I get shot in Fortnite, sometimes in Minecraft too. It is very very annoying to have that problem and it seems to be worst in worst. No matter if I lose 3HP or 200HP, I get the big frame drop. I know I have a laptop and not a gaming pc, but I have performance mode, all my settings are the most optimized possible, there is nothing that is not for performance. I have watched all the videos of frame drops in the world to try to solve that problem, but nothing workes. I am pretty tired of those, if anyone can help me, it would be appreciated.
https://linustechtips.com/topic/1340325-frame-drops/
9 minutes ago, Fromage50 said:
Hello everyone,
What are the specs of this laptop that you are playing on?
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/1340325-frame-drops/#findComment-14750640
Not with what you've provided. What are your temps like? What's the specs of the laptop? Plugged in or on battery? What resolution and quality settings? Give as much detail as you can. Use a tool like HWINFO64 to monitor while playing and report anything interesting there (temps, clocks, etc.).
Also, "performance" mode is meaningless. That's just saying it's not artificially limiting performance to save battery life, which wouldn't even matter if you're plugged in. It's not making anything work harder.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1340325-frame-drops/#findComment-14750649
Prossesor: AMD Ryzen™ 3 3250U Mobile Processor with Radeon™ Graphics
Video Card: Integrated AMD
Ram: 8GB
OS: Windows 10
Hard Drive: 256GB M.2 PCIe NVMe Solid State Drive
The temp of my cpu is around 75C and gpu is around 80C when i play. For the clocks, i know i cant change the gpu's one, but the cpu ya. The 3D resolution in fortnite is 50%, i play on 1280p by 720p. My laptop is always plugged.
(I am not really sure for my mother board)
https://linustechtips.com/topic/1340325-frame-drops/#findComment-14750686
7 hours ago, Fromage50 said:
So, can anyone help me pls??
This is difficult, because your system might just doesnt run this game well, lots of stuff going on, probably cpu intensive, on a cpu/gpu all in one solution, its possible the hardware just cant keep up.
However , i see it says single channel RAM, that isnt recommended for Ryzen cpus, so if you can try to buy another 8GB of RAM with the exact same specs as your already existing RAM, that would  make it dual channel RAM and possibly fix your issues , no guarantee though of course.
But yeah, Ryzen needs dual channel RAM.
-Scott Manley, 2021
https://linustechtips.com/topic/1340325-frame-drops/#findComment-14753298
