hi guys i have a corsair k95 platinum and one of my keys (the A key) to be precise,sometimes doesnt register,not sure if its going out or dirty,im wondering if i can replace the switch myself or are these soldered in? or does anyone know a good way to clean these things? the switch i have on it are the cherry mx speed.Thanks for any info on this,all other keys work fine hate to replace the board because of that one key.
https://linustechtips.com/topic/1340294-switch-replacement/
How bad is it underneath the keycap, when you pull it off?
Might just need a VERY damp cotton bud wiped around it.
My bet is they're soldered in - I've got a K70 LUX RGB
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1340294-switch-replacement/#findComment-14750275
Given that you have a 3 year warranty, take advantage of Corsair's RMA program.
If you don't have a keyboard to use during the RMA process, request for an Advanced RMA. They will charge the full value of the replacement to a payment method of choice, which will be refunded once they receive the faulty unit.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1340294-switch-replacement/#findComment-14750299
