need tech help
Go to solution Solved by JohnnyGrey,
Bottlenecking is where a component cannot be utilized to it's full potential because something else in the system is running a maximum potential. So in your case, the CPU might be running at 100%, while not being able to get information to the GPU quick enough, or in enough quantities to allow the GPU to be used at full potential.
There's bottlenecking in every system, sometimes small, sometimes major.
In your case, you're probably fine.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/134004-need-tech-help/#findComment-1783328
Bottlenecking is when a component(s) holds back another from reaching its full performance.
https://linustechtips.com/topic/134004-need-tech-help/#findComment-1783333
thank you
https://linustechtips.com/topic/134004-need-tech-help/#findComment-1783338
B
thank you ill look it up
http://en.wikipedia.org/wiki/Bottleneck
bottleneck is a phenomenon where the performance or capacity of an entire system is limited by a single or limited number of components or resources. The term bottleneck is taken from the 'assets are water' metaphor. As water is poured out of a bottle, the rate of outflow is limited by the width of the conduit of exit—that is, bottleneck. By increasing the width of the bottleneck one can increase the rate at which the water flows out of the neck at different frequencies. Such limiting components of a system are sometimes referred to as bottleneck points.
https://linustechtips.com/topic/134004-need-tech-help/#findComment-1783350
bottlenecking is mainly just when you have a lower end product mixed with a higher end product like if you mix a intel pentuim processor with a 780 which the Pentium would slow down the 780 and you would not get the full performance out of it and there may be some with that but it may be minuscule that you would not be able to tell
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/134004-need-tech-help/#findComment-1783353
