Sounds like damaged hard drive and or graphics card(damaged)
Check if airflow in case is blocked and  not overheating
Remove graphics card (and/or drivers ) in Control Panel > Device manager then rescan for hardware changes
Run CPUid to check temperatures when running in windowed mode.
If you can't do recovery, normally means harddrive is damaged as files located on damaged area.
chkdsk /f /r 2 or 3 times to get an idea if its the drive
https://linustechtips.com/topic/1339493-help-me-please/#findComment-14744393
