Currently getting a budget build done and am trying to decide on which to get between these mid-tower cases:
Phanteks Eclipse P360A ($140 NZD)
Corsair Carbide 275R Airflow Tempered Glass ($150 NZD)
Lian-Li Lancool II Mesh RGB Tempered Glass ($180 NZD)
I've pushed my budget pretty tight and would like to get away with only using the stock coolers.
My focus is on quiet (and easy to clean).
Personally, I'm leaning towards the corsair carbide, would love opinions/experience.
https://linustechtips.com/topic/1339272-help-me-decide/
I would go for the eclipse or Lian li. I personally love my o11d. They seem to have better airflow, look better, and are more spacious for building which might not seem important but is very nice to have.
I would recommend getting the phanteks, and getting a 5 pack of Arctic p12 non-pwm fans for great airflow
its only 25 usd for the 5 pack, and they’re great fans
https://linustechtips.com/topic/1339272-help-me-decide/#findComment-14742235
7 minutes ago, Caroline said:
The Eclipse is nice but if you've pushed your budget tight then why are you spending over $100 on a case?
Should I not? I've always thought a cheap case would be a bad idea.
Incase you missed it, those prices are NZD btw. Cheapest case I could get would be around $90 NZD with no fans.
https://linustechtips.com/topic/1339272-help-me-decide/#findComment-14742303
2 minutes ago, Ridguard said:
I see everyone has been avoiding that, any reason why?
ya it has holes on the front but there not good enough imo
https://linustechtips.com/topic/1339272-help-me-decide/#findComment-14742451
51 minutes ago, 1stMidnight said:
Their quality seems to be pretty iffy, and mesh is better.
Ah I see.
Yea, after doing some more research, I think I like the Phanteks the best out of the three.
Found two cheaper options that seem ok - the MSI MAG Forge 100R and the Deepcool Matrexx 50 ADD-RGB.
I am a bit dubious on them as I haven't found any reliable info yet (and I've gotten the impression that msi cases leave alot to be desired), if anyone has any experience with either.
https://linustechtips.com/topic/1339272-help-me-decide/#findComment-14742737
1 hour ago, Ridguard said:
Ah I see.
I would go with the phanteks, use the extra savings and buy some arctic p12s to go in the top and back for exhast.
https://linustechtips.com/topic/1339272-help-me-decide/#findComment-14742952
not the Deepcool Matrexx 50 ADD-RGB case as it has a solid front. bad air flow
the MSI MAG Forge 100R is ok still recommend the other 2 Lian-Li Lancool II Mesh or Phanteks Eclipse P360A or other mesh front cases but at the end of the day its up to you to decide.
my recommendations are based off a mesh front with good air flow. but there are case were you can give up a bit of air flow for looks or other stuff
still recommend airflow thow because your pc will run cooler, faster, and quieter
Edited by thrasher_565
https://linustechtips.com/topic/1339272-help-me-decide/#findComment-14743112
