right click not registering right
Kanna
I was playing Warzone and then all off a sudden I noticed that it was like not aiming properly and idk what happened to cause this, mouse is razer deathadder elite
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
22 minutes ago, Human1235234 said:
Did you try with other software? Other ports?
I tried another port yeah, I tried it in google chrome on some mouse button tester
Reminder⚠️
How old? Is the sensor dirty?
The mouse is like 4 almost 5 years old, I don't really know how to check if it's dirty
Reminder⚠️
Is one button harder to click than the other?
There is different sounds but I can't tell a big difference
Reminder⚠️
Then the switch is probably dead.
Dead? really?
Reminder⚠️
Death adder elites tend to sound different right and left click.
Dead? really?
First think I'd do is pry the right click casing up so you can see the switch underneath, then with a can of compressed air give it a proper clean, and if you have a thin paint brush and some IPA clean the switch with that as well
Okay so I actually took my compressed air and just blew it under the right click and yeah a dust cloud kinda came and now it seems to work like new
14 minutes ago, Human1235234 said:
Yes
Okay so not going to say I was any better but please don't just assume that it's dead without actually checking
Reminder⚠️
Do you not think I know I was wrong?
Glad to hear it, i would still suggest you get a little bottle of IPA and a paintbrush and give it a good clean. Also you may as well do the left click whilst your at it
Yeah I dusted that out too but nothing really came from there
Reminder⚠️
