I'm currently in the concept phase of making a sff pc in a old fat ps2 and most things are going smoothly, however I've come to realize that the motherboard needs to be oriented in a specific location to work and this location leaves little height clearance above the RAM and mobo power connectors. I think the RAM will be fine because the dummy board I'm using for scale is a bit older and has the ram slots closer to the side due to the power connectors having their own side, but that means now that I'm going to have trouble fitting the power cable in there. Any suggestions?
Just here for some fun.
PC Build 1: Great Ape (Main Rig) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/nKjHGX
CPU: Ryzen 3700X
GPU: ASUS GTX 1070Ti 8GB ROG STRIX
PSU: SeaSonic FOCUS Plus Platinum 750 W
Mobo: MSI MPG B550 GAMING CARBON WIFI
Case: Corsair 4000D
PC Build 2: Piccolo (Emulation/ITX/Transportable) > https://pcpartpicker.com/user/DJ_saiyanprince/saved/tDBdHx
CPU: Intel i5-11400
GPU: EVGA GTX 1060 3GB SC
PSU: EVGA SuperNOVA GM 550 W
Mobo: ASRock Z590M-ITX/ax
Case: Silverstone RVZ03
♪♫ "2-to the-1-to the-1-to the-3 I like good OC and RGB. Configure so much, you wouldn't believe. And I get more blue screen than a Walmart PC" ♪♫
https://linustechtips.com/topic/1337319-custom-sff-case-issue/
The 8 pin will actually be a perfect one, but the 24 is a bit more of a challenge. It'll basically be blocked from both sides by the ram and the case and being blocked by the case above it.
CPU: Ryzen 3700X
Case: Corsair 4000D
CPU: Intel i5-11400
https://linustechtips.com/topic/1337319-custom-sff-case-issue/#findComment-14727635
