I need help on my gaming rig, im looking at a few diffrent GPU options. i would like it to stay green side so please no amd suggestions.
should i get 2 gtx 680 classifieds?
1 titan?
1 690?
depending on the price 2 780s?
What should i get i have until june if not later, so the 780s should hopefully be out by then.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/13372-gpu-help/
best advice is to wait for linus to get the 7xx series and see how they compare to the 6xx series to see if they are worth the extra cash
 CPU: i5-6600k MOBO: ASUS Z170 Pro Gaming RAM: G.Skill 16GB 2800Mhz 15-15-15-35, GPU: Sapphire R9 290 SSD: Samsung 840 250GB HDD: Seagate Barracuda 2TB x2, Cooling: EK supremecy EVO ,EK-FC R9 290X with backplate, XSPC EX240 Crossflow & Alphacool UT60 240mm, XSPC D5 Bayres w/ Alphacool VPP655, 7/16-5/8 Compressions/Tubing, Noctua NF-F12 x4 PSU: Silverstone Strider Plus 850W Case: Nanoxia Deep Silence 1 http://valid.x86.fr/8g2m02
https://linustechtips.com/topic/13372-gpu-help/#findComment-143634
well the 780 is supposed to be a dumbed down titan rumors of course but it sounds pretty legit to me
https://linustechtips.com/topic/13372-gpu-help/#findComment-143637
With 7xx GPU's just around the corner, Best to wait and get 2 780's. Will be basically Titans with 5Gb ram instead of 6 and 12 of 15 SMX units enabled instead of the 14 in the Titan.
690 is irrelevant, is more expensive and less powerful than 2 670's, yet alone 680's.
https://linustechtips.com/topic/13372-gpu-help/#findComment-143686
