Looking for a prebuilt (as graphics card are hard to get right now) that can run Ubuntu on an Intel Platform, and Nvidia graphics card for cuda acceleration under 1600. Mainly used to train CNN, which SI should I go with
CPU: i7 5930K OC'd 4.5Ghz
Motherboard: Asus X99 Sabertooth
RAM: 64G Corsair Dominator Platinum
GPU: EVGA GTX980Ti Hybrid
Case: NZXT H440 Razer Edition
Boot: Intel 750 480GB
Storage: Micron M7 256GB+Seagate 3TB in acceleration mode
Backup: WD Blue 1T incremental for boot drive
PSU: Corsair AX860i
Display: Dell 2312HM
Cooling: H110i GTX
Keyboard: Topre Realforce
Mouse: Logitech G700s/G502s
OS:Win 10
The one that has the parts you need for your task at the best price.  Big Nvidia cards would likely mean a middle grade or upper grade System Interator.  There are a ton of them.  I’ve searched for a comprehensive list but I haven’t found one.  I could spit the few names ive heard but I wouldn’t call that a reccomentdation.  One thing you apparently want to do though when the thing arrives is look it over and fix what needs to be fixed. Build quality can apparently be very variable.
