How much memory do I need?
3 hours ago, shinegull said:Thanks, I guess i'll make a list or something
This, everyone's different but there are a few tiers that we know. 90% of games see no more performance above 8GB, some do better with 16GB and 16GB kits are the baseline these days so I wouldn't go below this. For professional use 32GB is a good baseline unless you have high memory requirements for something but likely if that's the case you'd already know that you have these higher requirements (unless you're new at it lol). Some of this is kind of a moot point since if you're building a work PC you usually aren't gonna balk at the $80 difference between 16GB and 32GB for a kit (They're pretty cheap...16GB kits like this for $70 or 32GB kits like this for $150) so starting at 32GB for work is what I'd recommend at a minimum for that. Having said all that, many of these applications recommend ECC or quad channel+ memory for stability/performance respectively depending on if it's a production environment so you have to consider that as well (Especially since good ECC sticks known to play well with Ryzen can be $140 per 16GB stick which is much more than normal memory and slower at 2666MT/s since 3200MT/s is hard to find, hard to locate on a QVL as compatible, and expensive). As of a few generations ago a lot of motherboards were capped at 64GB max and many laptops at 32GB but if you have a brand new system the cap is likely either 128GB or 256GB and kits that go together can be found up to that amount and frankly even capping out your memory isn't that expensive compared to a few years ago. I paid $175 per stick for each of my 4 x 3200 C14 memory and now they can be found for like half that. Also, definitely go with a high density kit which leaves you some DIMM's open for expansion later if you're not maxing out.
