Need help regarding ram.
Go to solution Solved by Stockholmes,
1 minute ago, FroXeNskUlL said:
I have build my System 2 weeks ago these are the following specifications
Ryzen 7 5800x
Asus rog strix B550-E
8x2, 16gb F4-3600C18D-16GTZRX
My question is that I want to add more ram in to my system so if I buy same ram that I'm using right now so I can get 32 gb ram in my system will this work and will I face any speed loss?
If you buy the same ram, no.
Ryzen 7 5800x
https://linustechtips.com/topic/1336694-need-help-regarding-ram/
Ryzen 7 5800x
Ryzen 7 5800x
Yes, it will work, as long as you get DDR4 at the same cas-latency (CL) you can get any set of RAM, just know that the slowest stick will be the speed it all runs at.
Edit: There will be no speed loss.
