I recently changed my CPU to Ryzen 5 3600x, when i replaced the CPU the bracket came off and i pushed with my hand and continue to building the PC. After starting the PC in bracket zone there is a vibrating noise cames up when only CPU fans working on higher RPM. I opened the front cover and i pushed to screw of one side and noise disappeared. After i take my finger back the noise back again too.
I tried to thight the screw's. It's works a little bit but after some hours due heat, the noise come backs too and If i make PC horizontal or upside down (lol) the noise dissapears.
My previous cpu is ryzen 3 2200g. Of course there is no issue before that.
My motherboard: MSI B450M PRO-M2 MAX
https://linustechtips.com/topic/1336657-cpu-cooler-bracket-noise/
You should take the bracket off and check for damage. You might have to replace it.
15 minutes ago, tkitch said:
post a pic of what you're talking about?
I think OP is referring to the motherboard's backplate as a "bracket" and it broke during the CPU cooler installation
Primary PC:
PSU tier list
How many watts do I need?
you're quite possibly correct, but that's why I want a picture because 'bracket' isn't very descriptive and could talk about a few things.
10 minutes ago, denizdeni said:
It's made from steel. How i can broke that thing?
You'll need to take the entire thing off and check for damage on the front and backplate. Is it the cooler that comes with the CPU (See image)?
If so you may just want to replace the whole thing with a cheap/better alternative...the Hyper 212 LED comes with a backplate system of its own so even if yours is broken it will work fine and be much quieter. It's available here for $ 35.
PCPartPicker URL: https://pcpartpicker.com/list/8GYLQD
System Specifications:
CPU: AMD Ryzen 9 5950x
Motherboard: MSI MEG X570 Unify
RAM: 32GB G.Skill Trident RGB PC4000 16-16-16-36
GPU: eVGA RTX 3090 K|ngp|n Hybrid W/ 120mm Noctua iPPC 2000 RPM Industrial Fans  (Undervolted, No OC Yet)
Case: Corsair 4000D W/ a 120mm Noctua iPPC 2000 RPM Industrial Fan in the Only Spot Without a Radiator
Storage: Samsung 980 Pro 2TB (Boot) + Samsung 970 Evo 1TB x 2 (RAID-0) + 8TB RAID-1 NAS Drive x 2 (RAID-1) + PERC H730 W/ Toshiba PX04SMB160 1.6TB Enterprise SSD x 2 (RAID-0)
PSU: EVGA - 1000 T2 Modular PSU
Display(s): Acer - Predator Z1 31.5" 2560x1440 165 Hz Monitor +TCL 55S405 55" 4K HDR Display (Gaming Mode) + Samsung 27" Display (1080p60 Trash lol)
Cooling: Liquid Freezer II 280mm W/ 140mm Noctua iPPC 3000 RPM PWM Industrial Fans
Keyboard: Corsair K68 RGB (Cherry MX Red)
Mouse: Cooler Master MM720
Sound: Logitech G Series G935
20 minutes ago, tdkid said:
is the plastic, acrylic or whatever it is clear pad on the backplate still on it?
yes.
Okay i'm checking it.
3 minutes ago, tkitch said:
For the temps:
Did you apply fresh paste when reinstalling?  You generally have to.
When installing screws on a heatink:  Make sure you just /start/ all 4, before even considering tightenting in an X pattern.
Like this:
The degree's always same even in the first day of it. I'm gonna use it like that.
16 hours ago, tkitch said:
For the temps:
Like this:
Yep, tightening 2 full turns on each screw at a time will ensure you stay even.
Your best bet is just snagging a better CPU cooler but definitely redo thermal paste during each removal if you're not going to...even cheap thermal paste from Amazon like Arctic Silver will be better than the stock paste and it's like $5-7.
On 5/14/2021 at 10:04 PM, tdkid said:
every time you remove the CPU cooler. its a good idea to clean off the paste from the cooler and the CPU and reapply it. the thermal paste most people say is the best is from thermal grizzly
Note that this is purely based on performance, not usability or suction to the CPU which is what turned me off to it. Also, 100% agree that it needs to be cleaned every time...depending on the machine I either use alcohol pads (High alcohol percentage like these) or a removal kit like this one.
Edit: Added a different link to the alcohol pads as the price for the others were scalper prices lol.
Edited by DanielNS84
