Cable Sleeving in UK
FMA
Is there a site/ shop (like Lutro0 Customs) in the UK where i can buy sleeved cables or at least someplace I can send some in to be sleeved. I've seen a bunch of videos and tutorials, but I cant go through the learning curve right now and buying them will be easier and quicker.
There's a couple of guys on the forums who'll do it for you, some of which do it professionally. Pexon PC's is a good place to check out http://pexonpcs.co.uk/ And he's on the forums so PM him and I'm sure he'll sort you out. He'll do your entire PSU if you wanted something like that.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
http://www.e22.biz/ stocks all of lutro0 customs sleeving as well as some other cool modding pieces
My rig: i5 2500k, MSI Z77A G45, Gainward GTX 980 Phantom, 8GB Corsair Vengeance, OCZ ZT series 750W PSU, 1TB HDD, 800D, fully water cooled. I am currently working on modding my HAF 912+ to fit a custom loop, here is the build log: http://linustechtips.com/main/topic/165963-project-viridis-water-cooled-haf-912/
I'm in the UK mate and have recently used Pexon, I had a custom set of cables made for my RM 750, a 24 an 8 and 4 6 pins for a £100. You don't need to send in your cables, so it's better if you ever need to RMA. he does extensions to but the price difference wasn't much for a full set.
http://i.imgur.com/nOJdrZI.jpg
MSI Z87 XPower, I5 4670k, 4x4gb Avexir MPower, 2 x HD7950, XFX Pro750w, Intel 335 180gb boot, 250gb Samy pro games, 60gb OCZ Vertex music, Monsta 420,ST30 360, 140mm / 120mm Akasa Vipers in push pull, D5 Vario, Koolance top, Bitspower ZMulti250, Fesser Fittings all round, Mayhems sunset Yellow, 32" LG monitor, 23" Asus monitor, Microlab Solo 7c's, Bheringer MS20's, R.A.T7, Steelseries Merc Stealth
I recently went through Shakmods who send them out to pexon, I got a full set for my RM750 consisting  of a 24, an 8, and 4 6 pins for a £100, he uses all MDPC-X sleave and does them in about 4 days. He does some good work. He does extensions too, but the price wasn't much cheaper than a full custom PSU specific, you don't send your cables off, which makes it a whole lot easier if you ever need to RMA your unit for any reason. http://www.shakmods.com/
These are mine mate.
http://i.imgur.com/49FwFvK.jpg
http://i.imgur.com/ypB8cTp.jpg
Thank you so much this is exactly what i was looking for.
No probs matey.
