Heyo so i have this sound my harddrive makes. Ik hard drives makibg sounds are normal but in such a constant interval? I am currently running a smart diagnosis with the WD dashboard. It has been making the sounds for a very long time and i alr ran a smart diagnosis months ago. Should i be worried about those sounds? My phone kinda picked it up wrong btw it doesnt sound as much as a "crash" ig
Sprache 001-1.m4a
https://linustechtips.com/topic/1336411-hard-drive-sounds/
Update: both the quick and full smart diagnosis lock up on 10%
Update 2: the sound is gone in Linux, but i cant finish the twst too. It locks itself in on 90% remaining (using smartctl)
Update 3 (lmao): its actually progressing further in linux tho i just used the quicl test which should finish in under 5 min
https://linustechtips.com/topic/1336411-hard-drive-sounds/#findComment-14719993
