Problems with Crosshair V Motherboard [SOLVED; CAUSE WAS CORRUPTED CMOS]
59 minutes ago, redcysteine said:It's about 9 years old, so may have something to do with it.
It did exactly that, but changing the cables around just makes the mobo ask for a proper boot device. I assume that the drives got messed up with the CMOS resets or with whatever made the mobo misbehave in the first place. Would formatting the drives help?
EDIT: I forgot to mention, this started happening after I disconnected the DVD drive (yes really) from the motherboard.
I can all but promise you it did, it's possible the BIOS has become mildly corrupted and is in need of flashing to fix.
If the battery falls below 2.9v's the battery will need replacement and, being it's 9 years old I've no doubt it's past due to be replaced.
You'll have to change the battery first and then attempt a BIOS flash.
BTW you can force a default boot by simply pressing and holding the powerbutton and repeat this for about three times. After that let it try to boot and you should get the "Overclocking failed" error message - You'll have to hit F1 to go in the BIOS.
Change things to all defaults, hit F10 to save and reboot again.
See if that helps.
