gpu 1050ti problem
15 minutes ago, doomsriker said:I mean if you have something like a spare toaster oven that you never plan to cook food in again (process coats oven in toxic fumes that cannot be cleaned out fully) you could give it a try but it is almost always a bandaid fix that could last anywhere from 5 days to 5 years but will eventually break again. I’m assuming you have already tried every single output your GPU has to insure that it’s not just a dead port. It is possible that you have a corrupted bios on the card which can be fixed if you have a PC with onboard graphics available to plug the GPU into like in this vid
good luck
Thanks for your opinion, i've seen lots of YouTubers that tried this method and it worked, but i Noticed something
I have to reboot the pc 3 times, then it shows 3 times a blank screen and stops, could this be a error code?
