Not sure if same memory sticks? (ADATA)
Go to solution Solved by bmx6454,
it should work fine, even saw someone on the amazon q&a section asking your exact question, and the answer said they were compatible. worst case scenario, return if it doesn't work, but it should be fine.
edit: i did find one with the same exact numbers: https://www.ebay.com/itm/324570317439?_trkparms=ispr%3D1&amdata=enc%3AAQAFAAACUBaobrjLl8XobRIiIML1V4Imu%2Fn%2BzU5L90Z278x5ickkXOzEvn0a4N9m%2Fs0oSQBjmpqShJ35eeUKRFaGhaBnS0SCZgbIv78UE1MzXtQ1IeJdYaeKYSBGAPTFEEwBOfKzvWDEXFneLUpXopeErBiTA40OmmHPzbK6v%2FqhHDhCixafhsPcgWH7bcvZbNcYwUzYDZ1z2f9lUJ3ti7gnbdAq5xzHxhBCLnZ7qyRh9z5kB1igPIvbxF6Zjtn%2F7783l3OA%2B3xzkRCDEKBRWVEAf%2BI7MPxuPzOHPslmwXjgx%2B15V6XSn8Vqf3KJwP8le0%2Bq0KfcR9KNcFp5gKfpDK9YtZ849WHhHPcjyzrg%2FX8Gwn1P6OSly9fc%2FA3yfwelh434Wzdul82J56VjopvJTOrWsGxTHSE2GRJ5yLuwoRNsusqrO2MmuQn%2FmhD2GJl%2BSD8Cwnm%2B3EfKFEwufMTcDNI%2Bu68OuMjq1fH62%2FpQQK8Fcer%2BjCp9HB37xTHxTA8NEG8LQ9XNKooD2TvTr1zR3PtdhgmSOZ0tUsj%2FDHZto%2B90BNqq6ZxLoba6wQJTQrFBZRpigTJPpyoP%2FOqfyY5A8ZeZtf3VZvAlPXG7Pbdm4w%2F4dsQ%2F49uLnD6FUUJXZYQ%2Fvu%2FldXweIDzbT8OUjSOEYBDSvgUYuPDC641IVKzNFzbbsh16UHFLBpI9jQ%2FDQYk0wroaXtKw%2FXnv%2B2zygwKp%2B8OCq76wt%2BlharSzhGHrNQ%2Bx6rf9em6al0m0L8LMuFDhd7LwpIwJmRk8H6e5NhuBMJ2CQvWPk%2F0%3D|cksum%3A3245703174393cd2decce70146f5bda5e77ce3e28cf1|ampid%3APL_CLK|clp%3A3268220&chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=324570317439&targetid=1192081308384&device=c&mktype=pla&googleloc=1022342&poi=&campaignid=12874650447&mkgroupid=124501424634&rlsatarget=pla-1192081308384&abcId=9300535&merchantid=6296724&gclid=Cj0KCQjwvr6EBhDOARIsAPpqUPF-_0gzpWwFM968CT9Ei8iADuEDcLGSAfzwoUzOBUzN7pBJtfCp0bQaApqwEALw_wcB
Hello. I wish to upgrade my memory and get another 8 gb of ram, so I started looking for the same ram that my computer came with. I believe I've found the same one, but there are some small discrepancies, like the number being (17) instead of (19), and the one i have having the number "10401233" while the other having "10400268". I have searched for a bit trying to find the exact same one, but this is the closed one i could find. I read multiple reviews online saying that people in my situation have had the same result, but i just came on here to double check. Thanks in advance.
Amazon link to memory i want to buy: ADATA DDR4 2666 8GB Single Tray at Amazon.com
The attached image is the one that i currently have.
https://linustechtips.com/topic/1334256-not-sure-if-same-memory-sticks-adata/
