Hardware problem or bloated OS/drivers?
Solved by Tan3l6,
OK I think I found the culprit - when "core Isolation" in the security option is enabled then the performance does go down.
But I'd prefer a bit speed over some security bug.
The thing is - on secondary 10 the option can be flipped on or off. On my main 10 (Insider) the swap button shows as if the "Core isolation" is disabled and a bug prevents it to be enabled. I think I have to go look up a registry "flip button"
Also the culprits actaully are Meltdown and Spectre.
