Why doesn't my python calculator work?
Go to solution Solved by Eigenvektor,
It usually helps if you provide a bit more info other than "it does not work". You're a developer after all, do some debugging 😉
At first glance, your code
    global fnum // HMMMMMM………
    f_num = int(first_number)
Their code
    global f_num
Hello there! i have been following some python tutorials on youtube.. the youtube channel was guiding us to make a calculator with Tkinter and python.. first, i tried it without watching the video.. i made something similar, but with my code, the 'add' button doesn't work.. i copied some code from the video tutorial and it works fine... what is wrong with my code? and can someone explain me the mistake i have done..
Python, Tkinter
here is my code:
from tkinter import *
window = Tk()
window.title("Calculator")
e = Entry(window, width=35, borderwidth=5)
e.grid(row=0, column=0, columnspan=3, padx=10, pady=10)
def button_add():
    first_number = e.get()
    global fnum
    e.delete(0, END)
def button_click(number):
    e.insert(END, number)
    print(number)
def button_clear():
    e.delete(0, END)
def button_equal():
    second_number = e.get()
    e.delete(0, END)
    e.insert(0, f_num + int(second_number))
# all the number buttons
button_1 = Button(window, text="1", command=lambda: button_click(1), padx=40, pady=20)
button_2 = Button(window, text="2", command=lambda: button_click(2), padx=40, pady=20)
button_3 = Button(window, text="3", command=lambda: button_click(3), padx=40, pady=20)
button_4 = Button(window, text="4", command=lambda: button_click(4), padx=40, pady=20)
button_5 = Button(window, text="5", command=lambda: button_click(5), padx=40, pady=20)
button_6 = Button(window, text="6", command=lambda: button_click(6), padx=40, pady=20)
button_7 = Button(window, text="7", command=lambda: button_click(7), padx=40, pady=20)
button_8 = Button(window, text="8", command=lambda: button_click(8), padx=40, pady=20)
button_9 = Button(window, text="9", command=lambda: button_click(9), padx=40, pady=20)
button_0 = Button(window, text="0", command=lambda: button_click(0), padx=40, pady=20)
button_add = Button(window, text="+", command=button_add, padx=39, pady=20)
button_equal = Button(window, text="=", command=button_equal, padx=91, pady=20)
button_clear = Button(window, text="Clear", command=button_clear, padx=79, pady=20)
# row 1
button_7.grid(row=1, column=0)
button_8.grid(row=1, column=1)
button_9.grid(row=1, column=2)
# row 2
button_4.grid(row=2, column=0)
button_5.grid(row=2, column=1)
button_6.grid(row=2, column=2)
# row 3
button_1.grid(row=3, column=0)
button_2.grid(row=3, column=1)
button_3.grid(row=3, column=2)
# row 4
button_0.grid(row=4, column=0)
# other buttons
button_add.grid(row=5, column=0)
button_equal.grid(row=5, column=1, columnspan=2)
button_clear.grid(row=4, column=1, columnspan=2)
window.mainloop()
these are the functions used by the creator of that video tutorial: ( as the rest of the code is same )
    current = e.get()
    e.delete(0, END)
    e.insert(0, str(current) + str(number))
def button_clearr():
    e.delete(0, END)
def button_addd():
    global f_num
    e.delete(0, END)
def button_equall():
    e.delete(0, END)
why doesn't my code work? can someone explain?
hey! i know to use a computer
https://linustechtips.com/topic/1334126-why-doesnt-my-python-calculator-work/
Their code
    global f_num
Their code
    global f_num
ohhhhh.... tbh, i feel ashamed of it.. omg! lol! i checked it for over 3 times and i didn't find it! Thank You Very Much!
Eh, it happens, especially if you've read something for a hundred times 😀
