Hey all, was wondering if anybody here could recommend a company that does custom case builds? I currently have the Phantek P600S and I love the case/design. It reminds me a lot of Master Chief armor and while I could do paint/mods to that case myself, I tend to like going overboard and want it bigger, either full-tower or supertower (for absolutely no reason other than my own inner child).
Edit: should add that I've tried working on the protocase cad program but I suck at cad. Will contact them eventually if there isn't a better option someone can recommend. Also has anybody done something like this? If so, what was the cost? Thanks!
https://linustechtips.com/topic/1333820-custom-case-fabricator/
Protocase is in the $1000 to $3000 range for a one-off. Hope you have deep pockets 😉
https://linustechtips.com/topic/1333820-custom-case-fabricator/#findComment-14702412
i answered a similar question a few days ago but they wanted a case like frieza's ship from the dragonball series. what you are wanting is a much easier design and simpler to get done but the same rules apply. what you are looking for is a specific case just bigger which does pose a few problems in trying to resize the case.
what is your budget for this?
are you looking for a plastic type covering or all metal? what about tempered glass?
there are many more questions you need to ask.
if you are looking for all metal then most metal shops should be able to easily build this case but you will need to give them specific dimensions for everything which would probably mean having to buy the Phantek P600S case and then scaling it up to what you want.
i dont know where you live in the world but this company is in florida US and they do custom work. Performance-PCs.com Homepage
https://linustechtips.com/topic/1333820-custom-case-fabricator/#findComment-14721727
