Hi , i just installed GTX 460 se GPU on my pc.but when i open a game moniter goes black and appears input not supported.some games shows in big screen.already installed the latest drivers and done every thing on google.but no luck.please anyone had a solution please help me.
https://linustechtips.com/topic/1333686-resolution-issue/
Is this the first time you're using the GPU? If you bought it online then there's a possibility that you could have been sold a bad GPU. The 460 is very old anyway, so if you're trying to play recent and demanding games then they will not run.
Desktop - i5-9600KF @4.8GHz all core, MSI Z390-A PRO, 2x8GB Corsair Vengeance 3000MHz, MSI GTX 1660S OC 6GB, WD Blue 500GB M.2 SSD, Seagate Barracuda 2TB 7200RPM HDD
Laptop - ASUS ZenBook 14 with ScreenPad, i7-1165G7, Xe iGPU 96EU, 16GB Octa-Channel 4200MHz, MX450 2GB, 512GB SSD with 32GB Optane
Old Laptop 1 - HP Pavilion 15, A10-9600P, R5 iGPU, 8GB, R8 M445DX, 2TB HDD
Old Laptop 2 - HP Pavilion 15 TouchSmart, i3-3217U, Intel HD 4000, 4GB, 1TB HDD
iPad 2018 - 128GB
iPhone XR - 128GB
https://linustechtips.com/topic/1333686-resolution-issue/#findComment-14699939
no.it worked properly 2 months ago.but i removed gpu from pc and install it today.now it didnt work properly.
https://linustechtips.com/topic/1333686-resolution-issue/#findComment-14699979
Check that all the cables and connections are properly seated then.
iPad 2018 - 128GB
iPhone XR - 128GB
https://linustechtips.com/topic/1333686-resolution-issue/#findComment-14700025
Like @A10-9600P said, the 460 is very old. The Circuit Board itself could have go bad on it's own, and the HSF compound can also have became aged and dried out.
The GPU is nearly useless in this day and age. Unless you are playing Games from the Era where the 460 was still fairly decent. Modern iGPUs have better support, and will play Games abet at lower settings.
https://linustechtips.com/topic/1333686-resolution-issue/#findComment-14700029
