Need a QUIET case
46 minutes ago, Jjp1215 said:I was actually looking into fractal design define 7 or the vektor RS, but I’ve seen they tend to get warm. Does the meshify line also have sound dampening stuff?
No, that was sort of my point. Sound dampening and good airflow are contradictory in a case. It can't dampen sound without cutting off airflow. Any place air can get through is a place sound can get out.
However, you can have the best of both worlds with quality fans. I'm partial to Noctua, but there's other quality fans from the likes of Be Quiet or Artic. Cheap fans are louder by nature, and also don't move as much air, meaning you've got to run them at higher RPM for effect. If you have good, quality fans, you can run them at low RPMs and they'll be virtually silent.
