So read this first. Its my other topic: http://linustechtips.com/main/topic/121986-start-up-problems-please-help/
Basically, i have been having this problem for over a couple of weeks now. Im going to flip out if i dont fix this. Im not even sure what the problem is anymore. I THOUGHT, it was the RAM. But i dont even know. I have been running my computer fine for a couple of days, then the problem happend again. Is it because i was running 4gb instead of 8? Or maybe because i only had 1 stick of RAM in? PLEASE help.
*Update: upon startup i received a windows error code. 0x00000e9 and unexpected I/o error has occurred.
https://linustechtips.com/topic/133341-help-big-problem-with-starting-up/
ok first if you think is the ram you should run a memtest
http://www.memtest.org/
then check the hdd integirty using hd tune
try defraging the hdd
having a single 4 gb stick wont cause those kind of issues only if the stick is failing and if it is a bsod will pop up i had dying ram on a laptop
if you can diagnose you might have issues with the os you might wanna reinstall windows
"I've been mad for fucking years, absolutely years, I've been over the edge for yonks..."
"I've always been mad, I know I've been mad, like the most of us are...very hard to explain why you're mad, even if you're not mad..."
"There is no dark side of the moon really. Matter of fact it's all dark."
Updated: upon startup i received a windows error code. 0x00000e9 and unexpected I/o error has occurred.
According to this:  http://answers.microsoft.com/en-us/windows/forum/windows_vista-system/error-0x00000e9/1d399016-d15b-44e9-8b42-f01e4432f639
That error happens when there is a problem with the hard drive.
Mystery is the source of all true science.
