Hey! I’m new to the former but I couldn’t think of a better place two look for help. I just moved and started redoing my setup and ran into some trouble with my PC, every time I boot it up I get no display my fans sound like they are at full blast and I can’t shut it down without having to flip the power switch on the back of my PSU. My motherboard, AIO, and GPU all light up but I can’t figure out what the problem might be. I appreciate any help thanks in advance!
-OB
https://linustechtips.com/topic/1333181-having-problems-with-computer-after-moving/
Pop the side panel open and just make sure all your connections are secure
GPU, CPU, 24 Pin
And then on the power supply side too if it's modular.
also look if something was broken, or think something was broken or leaking since you have an AIO.
I guess some of that is not the problem, RAM and the GPU is doing good and you know the cable/monitor is accepting the input?
(hard to know if you don't have other means to check)
If anything was loose inside the PC when moving as well? Could knock some things off or anything weird to the cables for the power delivery from the PSU (checking both ends).
GPU, CPU, 24 Pin
I did it and same thing, I’m really hoping it’s not the PSU.
