So i'm upgrading my PC for GAMING purposes and i'm thinking of going one of two ways with it
i could either go with an AMD APU like i have here: http://pcpartpicker.com/user/TheQRoks/saved/4cQ1
OR, i could go with old parts from the Intel and Nvidia camps and use these parts: http://pcpartpicker.com/p/3iGAC
I have my monitor and peripheral situation worked out and will be playing games at 1366x768
I want to know which is more for my money and if you have ANY changes, link them :)
*EDIT*
Both builds will instead be using a Corsair CX430
Linus once unboxed a Toblerone
https://linustechtips.com/topic/133266-build-vs-build/
I don't really have any links for you but I do have a suggestion, If there is one thing I have learned over the years, the one thing you want to make decent is the PSU, maybe look for a cheap be quit or thermal take psu.
Connor Freebairn - ConnorFreebairn@newman.cumbria.sch.uk
IT Technician & Certified computer geek.
https://linustechtips.com/topic/133266-build-vs-build/#findComment-1773417
Um these are terrible builds..... you wont really be gaming.
True, but maybe he dosent really have the money for anything better at the moment?
https://linustechtips.com/topic/133266-build-vs-build/#findComment-1773431
I suggest saving up for more. 250 on this isnt worth it. Save up another 250.
My income is $7 every two weeks...
and my parents won't let me work until i'm out of High School
i'm selling my xbox(both because i need money and because i don't play it) for this build
it's not something i can do
https://linustechtips.com/topic/133266-build-vs-build/#findComment-1773507
Maybe you can do some smaller jobs around the house or for some neighbours to get some extra cash?
If all else fails mine doge :P (Jk btw)
lulz it's funny you mention that
i actually helped my dad fix a Wii and got a few bucks from that :P
https://linustechtips.com/topic/133266-build-vs-build/#findComment-1773535
Oh well please dont waste it on this build. Use the xBox.
https://linustechtips.com/topic/133266-build-vs-build/#findComment-1773548
