Does water cooling increase efficiency?
Go to solution Solved by Guest,
41 minutes ago, The Blackhat said:
Yes…yes it does actually. Cooler silicon pulls less power.
But you didn't tell anybody why!!
Cooler temps = less leakage.
Quote
517W is air cooled and 460W is water cooled on pics.
It also uses about 41-45W on PCI-E now Vs 56W it used to take on air.
= OC headroom, you may take advantage of. Increase the Core frequency now.
Hello,
I need some help understanding this:
I have 3090 Suprim X on air. About 70C max and uses 520W on KP BIOS in Heaven 4. All good, and as it should be.
Then I got a new EK block, great. Installed it and ran the same benchmark, only uses max 460W or so, but clocks are the same. 2160Mhz Vs 2160Mhz.
GPU temperature was about 32C Vs 70C on air cooling.
If I use Furmark it uses the entire limit of 520W and even peaks at 530W.
Superposition uses max of 509W at 4K optimised. However, mostly sits at either 480W or 500W.
Any ideas fellas?
Does this mean that my GPU reached its clock stability and more power doesn't do anything really so it doesn't use the rest of the limit depending on application? It did with air cooler so just curious.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/1332591-does-water-cooling-increase-efficiency/
Not really changes the efficiency of the card. Efficiency is an electrical thing that yes, it does have to do with power consumption, but a cooler card does not consume less power. Hope this helps.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
Actually heat introduces expansion and resistance. So a colder running electrical component is a bit more efficient.
Yeah my card doesn't use 519W it used to in Heaven 4 it uses max 480W with average 460W or so now after being cooled down 40C down so it must make sense.
Main PC:
Case: TT P3
HTPC:
Man that power seems really high for that clock speed. My fe card hits those frequencies with < 350.
Core clock stays the same yes, but performance went up according to benchmarks. Also, it's on purpose. KP 520W BIOS flashed
Main PC:
Case: TT P3
HTPC:
Black Lightning
Intel Core i5-3570K @ 4.7 ghz
Asrock Z77 Extreme4-M
2x8 GB 1600 MHz Crucial Ballistix Sport
MSI R9 290X Lightning
Corsair Crystal 280X Black RGB
240 GB Revodrive 3, 64 GB Sandisk SSD
EVGA Supernova 1200 P2
Noctua NH-C14S
Quote
Never mind, issue not fixed.
I flashed 1000W BIOS and it only uses 45% of it, as if its power limiting itself when it shouldn't. Very strange. So this wouldn't be the power saving as it wouldn't be saving 350W because it's 40c cooler.
I also think that BIOS switch isn't working at all. Because I switch when PC is off, turn it on and it still has 1000W BIOS on. I'll flash both BIOSes few times to see if that solves it (even though when I switch it still says it has the 1000W bios on), otherwise out of options and I would have to try the GPU in another PC I guess / different PCI-e slot maybe regardless if it's 8x or 16x.
I might also try unplugging USB devices, that helped in the past.
Main PC:
Case: TT P3
HTPC:
