What it means the BIOS that is default on the mobo you want, may not be up to date enough to work out of the box with your CPU, and the system won't boot.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690319
2 minutes ago, Redpanda4376 said:
Ok, but what can I do about it?
Well, that is an issue. *some* motherboards....you'll have to read the manual to find out if yours is one of them, will allow you to update the BIOS without having a CPU installed. If your mobo DOES NOT allow this, then you';ll have to buiy the cheapest CPU the mobo will support, update the BIOS, then put in your newer CPU, and sell the old one
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690329
That's correct .👌
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690335
Is it worth doing or should I change MoBo instead
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690340
All B550s will say that, just make sure to get one that allows you to update the BIOS without a processor
1 minute ago, Crafter King said:
That's correct .👌
You can use the reaction check mark if you want
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690344
That's a judgement call. That's a nice board (IMO)  but the easy decider, is to read the mobo manual on-line, and see if you can update the BIOS without installing a CPU
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690346
Does this mean I dont need to update bios? Because it says it supports AMD 5000 seriesScreenshot_20210428-173014_Firefox.jpg
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690442
If the mobo maker says you are good to go, then you are good to go. PCPartpicker can't possibly be 100% accurate for everything, which is why they give you a warning.
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690452
Well, hang on a minute...
The mobo manual says you need BIOS revision F10 to see that CPU.
https://www.gigabyte.com/us/Motherboard/B550M-AORUS-PRO-rev-10/support#support-cpu
which was released:
https://www.gigabyte.com/us/Motherboard/B550M-AORUS-PRO-rev-10/support#support-dl-bios
On Sept 2020. So assuming the mobo BIOSD was updated before it left the factory, then you are good to go
but if it's an older board that's been in stock for a bit, it may have an earlier BIOS, in which case it will not POST.
Here is the mobo manul (warning: PDF file)
https://download.gigabyte.com/FileList/Manual/mb_manual_b550m-aorus-pro_e.pdf
You'll need to read through it and see what it says about BIOS updated without a CPU
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690473
which was released:
Thanks for the help
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690538
10 minutes ago, brob said:
The Gigabyte B550 Aorus Pro motherboard has Q-Flash Plus. This allows bios updating without a cpu installed.
That greatly solves the potential problem, thanks for letting everyone know 🙂
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690607
To add to that, if you do have to use the Q Flash Plus, @Redpanda4376 here's a really good video. Do note that he doesn't have the CPU in the board when he updates bios. Only the 24 pin connector is plugged in. No RAM, no SSD, nothing else.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1332350-will-this-be-a-problem/#findComment-14690629
