My RAM speed is showing up less than half the speed it should be
Pogan
Ive had My Gskill aegis 16 gb ddr4 3000 mz ram sticks for a while and all of a sudden my game is bugging out and i check my task manager and my RAM is at 1067 Clock  speed.
Any Solutions?
Any Solutions?
So, because RAM is DDR, which means Double Data rate, sometimes it will come up as half that at 1500, since 1500x2 is 3000. When it says 1067, that leads me to believe that your ram is running at the stock 2133Mhz, what you need to do is go into the BIOS and either enable XMP or manually set the ram speed to 3000Mhz
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
If you watch LTT Videos, you sometimes hear about XMP Profiles. Those can be found in your UEFI/BIOS - They can be considered overclocking and enable your RAMs "true potential". However, the game bugging out has nothing to do with the RAM speed "suddenly" lowering itself. You probably never ran more than 2133Mhz.
