I see USB replacements for pc cases, but I don't see any with a built in light. Do they exist? here's an example in car adapter form.
Motherboard: Asus Tuf X570-Plus | CPU: AMD Ryzen 7 5800x Eight-Core Processor | GPU: Zotac GeForce RTX 3080 10gb  | RAM: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL14 | Case: ATX Mid Tower Case | Storage: Samsung 970 Evo 500GB & 1TB M.2 | Display: Samsung C27HG70 27" 2560x1440 144Hz 1ms | Operating System: Windows 10
https://linustechtips.com/topic/1332067-led-built-into-usb-replacement/
4 hours ago, Haraikomono said:
what is it youre speciffically looking for, like a 3,5" case module ?
Or really just a usb 3.0 cable with 2 usb ports that have rgb and connect directly to motherboard ?
hes looking for a female pcb mount usb with rgb in it like on the corsair Obsidian Series 1000D. but in the 1000d looks like its on the outside i have not seen any yet.
or like the inwin rgb case
Edited by thrasher_565
might be looking more for something like this
Yes, the Razor or Corsair. The Razor usb ports look amazing. For now, I'll have to make do with stickers.
ya i seen your other post. imo its probably better to add leds or something in to that desk and wire it to a button.
hmm i found this
https://www.coolermaster.com/catalog/cases/mid-tower/mastercase-sl600m/
