G vans tactus is a good option.  Lamptron make a version of the same controller, but the g vans is cheaper I believe.
It has 6 channels, 30 watt per channel, touch screen, multiple color options.  It also comes with 6 tensor sensors, which you can use to set-up Automatic fan control.
Not to mention aluminum construction.
https://linustechtips.com/topic/133120-a-good-fan-controller/#findComment-1771322
Do you work for G vans?
So I can put anything here?
https://linustechtips.com/topic/133120-a-good-fan-controller/#findComment-1771335
No (hence why I mentioned the lamptron too)  Phobya also has a version of it for the same price as the g vans.
I believe the only difference is the color of the PCB
Sorry for wanting to leave detailed reasoning for why he should choose it?
https://linustechtips.com/topic/133120-a-good-fan-controller/#findComment-1771340
Two of these.$32 each, paint the finger sliders to the color you want to match and your good to go.
BitFenix Hydra Pro Fan and LED Controller
http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_511&products_id=20625
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/133120-a-good-fan-controller/#findComment-1771417
NZXT Sentry Mix 2...best of both worlds.  A little bling but not overpowering.......
http://www.nzxt.com/product/detail/129-sentry-mix-2-fan-control.html
Case: Silverstone SG09B Motherboard: MSI Z10 Morter M-ATX CPU: I5-6600K  Ram: Corsair LP 2400 DD4 16GB GPU: MSI RX 480 Storage: Seagate HDD Baracuda 2TB x2, Crucial M200 500GB SSD X2 (Raid 0)PSU: Silverstone Strider Gold 1000W w/PP05E Kit
"When to say :blink: WTF :blink: ....$2K rig only used for Minesweeper and Internet Checkers marathons...."
https://linustechtips.com/topic/133120-a-good-fan-controller/#findComment-1771782
I was gunna choose that for my post, but the controller I posted also has a feature specific to his fans, so I figured I better show him that..
https://linustechtips.com/topic/133120-a-good-fan-controller/#findComment-1771916
