Headphone Advice!
Go to solution Solved by NannerBeans,
Okay so just what would you guys recommend then? No amp, just good headphones? If so, what model should I get. The reason I wanted an amp was to adjust my level appart from the main control on pc.
Normally I would recommend Hifiman HE400 for the $300 price range but those might need an amp. Beyerdynamic DT770/880/990 are great as well as AKG K701/702 and there are a few others I just can't think of right now.
And there is a cheap Syba amp/dac that shearme tends to like for $40 on Amazon.
Ok, so I watched this video the other day on Tek Syndicate's channel saying sound cards were pointless for pc gaming as they basically do the same thing a motherboard audio output.. I am willing to get an O2 amp but first I need a better pair of headphones. The one's he's recommending aren't available where I live (Montreal, Canada) and I would have to order them online (wich I won't because I am an impatient man and want them now.) I am looking to spend around 50$ before tax and was looking at something over-the-ear more than ON-it since I have to wear glasses when I game. For sure I have preferences in sound but around 50$, it's no time to be picky.  What would you guys recommend?
P.S. No headset as I already have a mic and am looking more towards sound quality.
Thanks in advance!
I have no consistency in my upgrades.
https://linustechtips.com/topic/133008-headphone-advice/
$50 headphones and a O2 + ODAC would a terrible mix, I wouldn't recommend getting a USB Amp/DAC until the $200 range at which point a E10 will serve you well. As for headphones I remember the PX360 going for $50 on amazon IDK if it's still available at that price anymore.
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/133008-headphone-advice/#findComment-1769960
well first of i would spend more on the headphones first and then get the amp you want
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/133008-headphone-advice/#findComment-1769964
better headphones.. and there is quite a bit of difference between most onboard audio especialy in the settings you get... but realy its up to your ears to decide if you like what you hear..
a good pair of quality headphones like the others have said is where you should start... headphone amp doesnt add much unless you have good headphones to drive them
https://linustechtips.com/topic/133008-headphone-advice/#findComment-1769995
Common misconception. They can actually be worse  :unsure:
You're better off taking the money you'd spend on headphones + O2/ODAC and spending it on expensive headphones that don't require an amp.
Error: 410
https://linustechtips.com/topic/133008-headphone-advice/#findComment-1770027
https://linustechtips.com/topic/133008-headphone-advice/#findComment-1770044
Like everyone else said, spend your money on headphones instead of a dac/amp. Your headphones are the weakest link in the chain do that would be where the most noticeable difference would be.
https://linustechtips.com/topic/133008-headphone-advice/#findComment-1770068
https://linustechtips.com/topic/133008-headphone-advice/#findComment-1775148
