Help?
Solved by OrangeSunshine,
As long as you have a good quality PSU with the right connections, I would wager you will be alright. Your CPU seems to consume about 65w and your graphics card about 125w from what I can find. The minimum recommended PSU wattage for the card is 400w, so I would probably go with a 400w one at a minimum.
*Edit* Sauces I found.
https://www.cnet.com/products/intel-core-2-duo-e7500-2-93-ghz-processor-series/
https://www.gigabyte.com/Graphics-Card/GV-N98TGR-512I#ov
https://www.techpowerup.com/gpu-specs/geforce-9800-gt.c635
