Ok to plug in fan?
Solved by Fasauceome,
yeah usually it's fine, but it can be annoying to plug into a fan header that has no pre-defined fan curve so keep that in mind, and in general it's a good idea to turn the PC off anyway cause you don't want to bump your hands into PC components that are operating (typically other spinning fan blades)
Featured Topics
halfbood_drag0n ·
2
10
1
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling3
