PowerColor Red Devil RX580 Heating problem
Hi, I recently purchased a second hand PowerColor Red Devil RX580 8GB. Upon running I noticed that the card gets really hot when running benchmarks and playing games. The temperature is around 76°C± with auto fan curve running at 90%+. And sometime 100% at 80°C. I've tried replacing the thermal paste with a Artic MX-4, no luck. Tried changing the oily thermal pads to Thermalright Odyssey thermal pads, a thickness of 0.5mm and 2.0mm, still no luck. So I thought it might the thermal was too thick since I measured it was 2.0mm uncompressed and 1.5mm compressed, however the thermal pads I have was hard and not really easy to compressed, so I changed to 1.5mm, again still no luck. This is getting frustrating as I have no idea what else to do. I have a Sapphire Nitro+ RX580 8GB. I ran the same benchmarks and games, the temperature is 70°C±, however the fan speed never exceed 50%. Please help, could it be the heatsink leaked the working liquid or something? Is that even possible? I noticed 1 outer fin from the heatsink was slightly bended, I bended it back into shape.
Could be the case that whoever you purchased the card from flashed an overclocked or mining BIOS to the card and didn't change it back. It's possible to find stock BIOS images, for example: https://www.techpowerup.com/vgabios/?architecture=AMD&manufacturer=Powercolor&model=RX+580&version=&interface=&memType=&memSize=8192&since=
Just be warned, that if you do attempt to flash the BIOS on the card, you can brick it.
Might be worth it to save a copy of your BIOS from the card to a hex file, and compare it to a "stock" BIOS file.
Hi, thanks for the prompt reply. I've flashed from the 1st to the 3rd BIOS, as those matched mine. Sadly, nothing changed, the temperatures are still high, fans are running at 100% at a temperature of 80°C+...
try undervolting. it will run at 1.2V stock. try 1.1V with msi afterburner or radeon software
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
