if estimates are right, it might be teh 5000 series by the time you can find them in stock regularly.
supply should "clear up" by 2023.
which means perfect supply will take longer.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1328694-buyers-guide/#findComment-14662189
19 minutes ago, Dr_Dissection said:
Should I buy RTX 3000 series cards if i can find one or Wait for the RTX 4000 series ?
If I can find them at MSRP then go go go get it.
And as per what helpfultechwizard says is tru then u can sell it for nearly same price later.
(A bit of pun intended.)
What are ur specs right now btw?
(Bcuz an "upgrade" will depend on what your old system is. If it's a 2080ti I won't bother unless u can sell 2070-2080ti at very good price and 30 series GPU is nearly at the MSRP)
https://linustechtips.com/topic/1328694-buyers-guide/#findComment-14662201
"should"?
what are your spces? what games do you play? Why do you need such a high end gpu in the first place?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1328694-buyers-guide/#findComment-14662741
you could probably get a 2080ti sold for its launch msrp, adn get a 3080 for a bit more, even at a scapled price, whcih would be much faster.
Bios database
prior build:
https://linustechtips.com/topic/1328694-buyers-guide/#findComment-14662840
2 hours ago, SavageNeo said:
"should"?
I am a engineering student working in the automotive sector, My spces are a Laptop with i7 RTX 1660ti, I play Rainbow six ; Thanks For Responding
https://linustechtips.com/topic/1328694-buyers-guide/#findComment-14663063
5 minutes ago, Orian Pax said:
that's what i said there. 😇.
you said if you could get it at msrp. I was pointing out that a scalped on would also work.
Bios database
prior build:
https://linustechtips.com/topic/1328694-buyers-guide/#findComment-14663143
i see, then it was the wrong line.
it should have been this one 👇
and this one "If it's a 2080ti I won't bother unless u can sell 2070-2080ti at very good price and 30 series GPU is nearly at the MSRP) " msrp of 2080ti i should extended the sentence.
anyway moving 🙃.
https://linustechtips.com/topic/1328694-buyers-guide/#findComment-14663155
