Audio setup planning help
Solved by OrangeSunshine,
I use a Focusrite Scarlett 2i2 to accomplish something similar. It is a slightly cheaper interface than the GoXLR, but is arguably a little less feature rich. It has two instrument/mic inputs w/ independent gain control for both, monitor outputs, and a headphone jack. The headphone jack and monitors have their own volume control. Also there is a monitor toggle, so you can output sound to your speakers, headphones, or both. Plus it is pretty sweet for recording if you ever need to do that. They typically run about $160, and they are typically set up in music stores, like guitar center, to play with before you buy.
