motherboard chipset question & CPU
First of all B85 is a budget option with fewer SATA 6Gb/s ports, lower quality Onboard Audio and no support for high frequency RAM(think 1866, 2133, 2400mhz).
Going with a 4670K is a good idea because having an unlocked processor gives you the option of overclocking it in a few years time and extending the lifespan of your rig.
It is true that a 4440 is only marginally worse than a 4670K but a 4670K will provide you an extra year and half in lifespan by overclocking.
If you are on a very tight budget buy an i5 4670K with a MSI Z87 G43(non gaming). It is a good combo and G43 has almost all the features you will need.
Hope it helps. ![]()
For more info on chipsets, follow this link - http://www.pugetsystems.com/labs/articles/Z87-H87-H81-Q87-Q85-B85-What-is-the-difference-473/
