Budget (including currency):  600 USD
Other details:  I'm planning to upgrade my PC and I want it to be white themed but also got them Performance, for now my priority to upgrade is the motherboard and Processor, Any Suggestion?
(I'm planning to get R7 5800x is it good for 2060?) (I'm also looking for a good white motherboard)
Current PC:
CPU                      Intel Core i5-9400 3.90GHz 6-Core Processor
Motherboard      Asus EX-B365M-V5
RAM Memory    GSkill Ripjaws 16GB 3200Mhz
Video Card         GeForce RTX 2060 6GB ROG Video Card
Power Supply    730 W
https://linustechtips.com/topic/1326336-need-help-upgrading-my-pc/
if you plan to also upgrade the gpu at some point, 5600x is a good option for gaming, 5800x if you do other work as well, such as video editing.
if you plan to keep the 2060 for a longer time, something like a 3600 or a 10400/11400 would be cheaper options that better match 2060's performance
I also plan to upgrade my GPU in the future to 3060 or 3070. Any good white motherboard suggestion?
And here am i planning to buy an HD6870
My rig
Cpu:pentium g3240
Psu:seasonic 620 sii
8gb ram
But my suggestion is for like genral gaming and stuff if you will not utilize rtx on your work then amd all the way and also for long term use but if you want to upgrade then nvida rtx 2060 then jump to 3000 series but if you can like spend more i highly suggest 2070 or 2080 so you wont be needing to upgrade
Just my opinion
