Budget: $1000-150$
Country: USA
Games, programs or workloads that it will be used for: Fortnite, Blender, and Valorant
Hello, Im a first time pc builder and I was picking out my parts Im finished with everything except the GPU. I was wondering if any experienced pc builder could recommend a GPU in my budget and take a look at the parts I picked along with advice on what to improve. I mostly play fortnite and do graphic design Im looking to average around 100-140 frames. PARTS:https://pcpartpicker.com/list/g6kFnL
https://linustechtips.com/topic/1326014-pc-build-help/
Welcome to the forums. We are currently in GPU Hell - everything is out of stock and jacked up in price. You're going to have a hard time finding any GPU in stock at a reasonable price right now unless you play the restock game really well.
4 minutes ago, EpikSippy said:
This doesn't actually link to your list - there should be an option on your list to share it.  If you have an Intel-based system and you're not planning on buying an F-series CPU, it might be worth just running on integrated graphics until you can find something in stock at a reasonable price.  Do you make money from your graphic design?
It's entirely possible that I misinterpreted/misread your topic and/or question. This happens more often than I care to admit. Apologies in advance.
珠江 (Pearl River): CPU: Intel i7-12700K (8p4e/20t); Motherboard: ASUS TUF Gaming Plus Z690 WiFi; RAM: G.Skill TridentZ RGB 32GB (2x16GB) DDR4 @3200MHz CL16; Cooling Solution: NZXT Kraken Z53 240mm AIO, w/ 2x Lian Li ST120 RGB Fans; GPU: EVGA Nvidia GeForce RTX 3080 10GB FTW3 Ultra; Storage: Samsung 980 Pro, 1TB; Samsung 970 EVO, 1TB; Crucial MX500, 2TB; PSU: Corsair RM850x; Case: Lian Li Lancool II Mesh RGB, Black; Display(s): Primary: ASUS ROG Swift PG279QM (1440p 27" 240 Hz); Secondary: Acer Predator XB1 XB241H bmipr (1080p 24" 144 Hz, 165 Hz OC); Case Fans: 1x Lian Li ST120 RGB Fan, 3x stock RGB fans; Capture Card: Elgato HD60 Pro
翻生 (Resurrection): CPU: 2x Intel Xeon E5-2620 v2; Motherboard: ASUS Z9PR-D12 (C602 chipset) SSI-EEB; RAM: Crucial 32GB (8x4GB) DDR3 ECC RAM; Cooling Solution: 2x Cooler Master Hyper 212 EVO; GPU: ASRock Intel ARC A380 Challenger ITX; StorageCrucial MX500, 500GB; PSU: Super Flower Leadex III 750W; Case: Phanteks Enthoo Pro; Expansion Card: TP-Link Archer T4E AC1200 PCIe Wi-Fi Adapter Display(s): Dell P2214HB (1080p 22" 60 Hz)
壯麗 (Glorious): Mainboard: Framework Mainboard w/ Intel Core i5-1135G7; RAM: G.Skill Ripjaws 32GB (2x16GB) DDR4 SODIMM @3200MHz CL22; eGPU: Razer Core X eGPU Enclosure w/ (between GPUs at the moment); Storage: Samsung 970 EVO Plus, 1TB; Display(s): Internal Display: Framework Display; External Display: Acer (unknown model) (1080p, 21" 75 Hz)
https://linustechtips.com/topic/1326014-pc-build-help/#findComment-14643103
Budget: $1000-150$
Country: USA
Hello, Im a first time pc builder and I was picking out my parts Im finished with everything except the GPU. I was wondering if any experienced pc builder could recommend a GPU in my budget and take a look at the parts I picked along with advice on what to improve. I mostly play fortnite and do graphic design Im looking to average around 100-140 frames. PARTS: https://pcpartpicker.com/list/
that just leads me to my list
https://linustechtips.com/topic/1326014-pc-build-help/#findComment-14643106
https://linustechtips.com/topic/1326014-pc-build-help/#findComment-14643118
Iv made around 40 dollars the main reason im getting a pc is to improve the quality of my work when its done rendering my qualitys really bad.
https://linustechtips.com/topic/1326014-pc-build-help/#findComment-14643168
