No signal on monitor
Upbeat69truck
I have an LG 32” UHD monitor. When I went to turn everything on to post my monitor just says no signal. What can I do.
Is the DP cable or HDMI in the GPU?
Have you checked the RAM one stick at time?
We need more information.
First watercooled System
Build Name: Frost
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: EK Mystic Fog
PSU: EVGA Supernova 1000w G3 w/ custom modmesh black & white cables from cablemod
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: HyperX Quadcast
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS
Camera: Razer Kiyo Pro
I have tried both hdmi and DisplayPort cable into my GPU and neither work. I have not taken out both rams one at a time
Well try the ram sticks one at a time and see if you get signal.
I had this problem with a brand new kit of ram and one of them was DOA.
Build Name: Frost
