Budget (including currency): 2400 USD
Country: Norway
Games, programs or workloads that it will be used for: General games (COD WZ/MW/CW, Rainbow 6, Satisfactory). Some editing work with adobe premier. School work
What I was thinking:
The partpicker lists cost in my county is 2338.92 USD 19 902 NOK.
I want to make a semi white build, but do not know if these part are good and if its any better parts to choose. I dont know how I am going to controll the ll120 fans, any recommendations on how to control, or other fans. Thx for any tips in advance.
https://linustechtips.com/topic/1325775-semi-white-build/
Country: Norway
this will give you the white color scheme your looking for with much better performance.
my signiture was cool, but its a lie now
https://linustechtips.com/topic/1325775-semi-white-build/#findComment-14641196
PCPartPicker Part List: https://no.pcpartpicker.com/list/ydwNHz
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  (kr4990.00 @ Proshop)
CPU Cooler: Corsair H100i RGB PLATINUM SE 63 CFM Liquid CPU Cooler  (kr1529.00 @ Proshop)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  (kr1539.00 @ CDON NO)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  (kr2681.00 @ Proshop)
Video Card: NVIDIA GeForce RTX 3080 10 GB Founders Edition Video Card  (kr8000.00)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (kr1075.00 @ Proshop)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (kr1299.00 @ Proshop)
Case Fan: Corsair LL120 63 CFM 120 mm Fans 3-Pack  (kr1111.00 @ CDON NO)
Case Fan: Corsair LL120 63 CFM 120 mm Fan  (kr454.00 @ Proshop)
Custom: Corsair Force Series MP510 960GB M.2 SSD (Purchased)
Total: kr22678.00
Generated by PCPartPicker 2021-04-12 17:49 CEST+0200
Here is my list, 5600x was overpriced to the point where you should just get a 5800x.
https://linustechtips.com/topic/1325775-semi-white-build/#findComment-14641198
You can use this https://no.pcpartpicker.com/ for norwegian prices
10 minutes ago, Onefi007 said:
Mixing memory kits like this means risking the XMP profile to not work. Better get a 4x8GB kit.
Desktop benching:
https://linustechtips.com/topic/1325775-semi-white-build/#findComment-14641206
