SFF Custom loop build opinion
1 hour ago, Kickus said:Hey guys,
My first post on the forum, sorry if the place is incorrect but I'm talking about custom loop water cooling so...
I want to get an opinion about the build that i'm planning to make. It's going to have on 240mm radiator for CPU + GPU. What are your opinions on this build?
Build:
Thermaltake Core G3
Gigabyte X570 Gaming X
Aorus RTX 2060 Xtreme 6G
32 Gigs of Ram
These parts I have now, but air cooled (GPU has a few milimetres of clearance and the CPU's cooler is over the case (temporary))
I ordered:
EK Coolstream SE 240 (slim dual)
2x EK-Vardar 120ER
EK-Classic Pump Reservoir 160 SPC PWM
EK-Quantum Velocity D-RGB - AMD Nickel + Frosted Plexi
for the GPU I ordered Bykski Waterblock for the corresponding GPU
And of course all the accesories that I would need.
How will my thermals look like? I'm not a overclocker, I just like a quiet build
If you aren't going to overclock, I think you will be fine. Even better if you're willing to undervolt.
