Budget (including currency): 2300 usd
Country: United States
Games, programs or workloads that it will be used for: fortnite Minecraft and school
Other details this is my first build and im just making sure that im not making some horrible desition or anything before I start buying all the parts
https://linustechtips.com/topic/1325733-picking-parts-for-first-pc/
Don't order from crucial you can find cheap brands just as good on amazon...      Intel is cheaper and doesn't get as hot as AMD (I like and but am currently using intel bc the price) and you can probably find a cheaper mother board that Is just as good also with spending less you can get a cheaper gpu I would say get an i5 processor I still have a core two quad that runs really good and have as my secondary pc
3080 is overkill for 1080p, especially with a 3700X. It's going to be bottlenecked by the CPU, so you're just leaving performance on the table. Either get a least a 1440p monitor or 3060/3070 instead.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
1) You don't need to buy seperate thermal pasteZ
2) If you don't have a graphics card to use for now you should just go with a 10700
3)I would get this power supply https://www.amazon.com/Corsair-Bronze-Certified-Modular-Supply/dp/B00ALK3KEM/ref=asc_df_B00ALK3KEM/?tag=hyprod-20&linkCode=df0&hvadid=312780390407&hvpos=&hvnetw=g&hvrand=4402197533215170618&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9003432&hvtargid=pla-404766791519&psc=1 I know it is not as high of wattage, but it's plenty and is from a reputable brand.
4) If 5600x comes to MSRP you should buy it since you need pretty good single core perfomance to drive 240hz
5) Drop the graphics card down to a 3060ti or get a 1440p 240hz monitor (which are definitely not cheap https://pcpartpicker.com/product/Ltxbt6/acer-xv272u-xbmiipruzx-270-2560x1440-240-hz-monitor-umhx2aax03)
Intel doesn't get as hot as AMD? What planet are you living on?
Ryzen is better for over locking though but I was temporarily playing fortnite on celeron so you should be good with an i5 or i3 the official minecraft gaming laptop is running a stander pentium so for what you are doing you should be good with an i3 and a 1050 ti
1 minute ago, Surestgarlic2 said:
Amd used to overheat the only time intel gets as hot as AMD was back in pentium 4 days
You're bonkers. AMD runs much cooler than Intel.
Sorry, I'm not trying to pile on you here, but you keep spouting nonsense. Intel OCs far better than Ryzen, at least until 10th gen. They both are fairly mediocre at OC now.
Bruh I have been building PC's since I was 10 years old 20 years later i think I know that amd  gets hotter than intel still I mean you can go either way but that is just my opinion
4 minutes ago, Surestgarlic2 said:
i think
Dont think. Research.
Also, use the damn edit buttons or keep collecting ideas till you can type no more.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($324.99 @ Newegg) 10700 if you can't find the 3080 or a spare GPU.
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  ($164.90 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($88.99 @ Amazon)
Storage: MyDigitalSSD BPX Pro 960 GB M.2-2280 NVME Solid State Drive  ($99.99 @ Amazon) much faster than the crucial P1.
Video Card: EVGA GeForce RTX 3080 10 GB FTW3 ULTRA GAMING Video Card  ($879.99)
Case: Lian Li LANCOOL 215 ATX Mid Tower Case  ($87.98 @ Newegg)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($108.78 @ Other World Computing)
Monitor: Westinghouse WM32DX9019 31.5" 2560x1440 144 Hz Monitor  ($254.98 @ Newegg)
External Storage: Western Digital 2 TB External Hard Drive  ($62.99 @ Amazon)
Laptop: Apple MacBook Air (Mid 2019) 13.3" 2560 x 1600 60 Hz Core i5-8210Y 1.6 GHz 8 GB Memory 256 GB Storage Laptop  (Purchased For $0.00)
Total: $2183.58
Generated by PCPartPicker 2021-04-12 10:33 EDT-0400
8 minutes ago, Surestgarlic2 said:
i think
you think, i think, who confirm?
Apparently not. Not sure what else to say here. You're just flat out wrong.
